I need help setting up a VPN gateway for an existing Virtual Network
Terry Phillips 21 Reputation points
2026-05-15T16:20:45.3933333+00:00
I am trying to set up a VPN gateway so that developers can remotely access certain VMs in Azure. I am confused about the exact steps to do this with our existing network.
Azure VPN Gateway
Azure VPN Gateway
An Azure service that enables the connection of on-premises networks to Azure through site-to-site virtual private networks.
Andreas Baumgarten 132K Reputation points MVP Volunteer Moderator
2026-05-15T19:09:53.0233333+00:00
Hi @Terry Phillips ,
it is possible to increase the IP Address space of the Virtual Network from /24 to /16.
If your Virtual Network is 10.0.0.0/24 with a related subnet of 10.0.0.0/24 you can extend the IP Address space of the Virtual Network to 10.0.0/16.
This way you are able to create the GatewaySubnet with for instance 10.0.1.0/27.
(If the reply was helpful please don't forget to upvote and/or accept as answer, thank you)
Regards
Andreas Baumgarten
  1. Andreas Baumgarten 132K Reputation points MVP Volunteer Moderator
    2026-05-15T16:43:34.5233333+00:00
    if there is an existing virtual network in your Azure environment please take a look here:
    Tutorial: Create and manage a VPN gateway using the Azure portal
    More information regarding the Point-To-Site VPN connections you will find here: About Point-to-Site VPN
    Regards
    Andreas Baumgarten
