Issues setting up Surface Pro on a business account
Benjamin Blaha 0 Reputation points
2026-05-12T18:37:28.5766667+00:00
When attempting to set up my new surface pro using my business account, I'm getting server error code 80180014.
Surface | Surface Pro | Install and update
  1. Thomas4-N 16,375 Reputation points Microsoft External Staff Moderator
    2026-05-13T06:14:56.23+00:00
    Hello Benjamin Blaha,
    It must be noted up front is that 80180014 is not something you can fix from the Surface itself. It's the tenant (your organization's Microsoft 365 / Intune setup) refusing the enrollment, so every one of the fixes the AI listed has to be done by your company's IT admin in the Intune / Microsoft Entra admin center, not by you on the device.
    What you can do is hand this to your IT team so they know exactly where to look. Once they adjust the organizational setting, you can restart the Surface setup and the work account should go through.
    2026-05-12T18:37:48.6266667+00:00
    Error 0x80180014 during setup with a business (work/school) account is an Intune/MDM enrollment issue. It typically occurs when Windows MDM enrollment is blocked in Intune or when the device is being re-enrolled and is still blocked in Windows Autopilot.
    Use the following steps; an Intune/Microsoft Entra administrator must do these in the tenant that owns the business account being used on the Surface Pro.
    1. Check if Windows MDM enrollment is blocked
    2. Sign in to the Microsoft Intune admin center.
    3. Go to Devices > Enrollment restrictions.
    4. Select the relevant device type restriction (for example, All Users).
    5. Select Properties > Edit (next to Platform settings).
    6. Under Windows (MDM), make sure it is set to Allow.
    7. Select Review + Save, then Save.
    If Windows (MDM) is set to Block, the device cannot enroll and will show 0x80180014.
    1. If this is an Autopilot/self-deploying or pre-provisioned device
    If the Surface Pro is being reused or re-enrolled via Windows Autopilot and you see 0x80180014, the device may be blocked by the one-time enrollment limit:
    1. In the Intune admin center, go to Devices > Windows > Enrollment.
    2. Under Windows Autopilot, select Devices.
    3. Find and select the Surface Pro that is failing with 0x80180014.
    4. On the toolbar, select Unblock device.
    5. Redeploy the Windows Autopilot deployment profile to the device and run setup again.
    6. If enrollment is being done as a personal device (Set up for work or school)
    If the device is being set up using Set up for work or school and is treated as a personal device, and personal Windows enrollment is blocked in Intune, enrollment will fail (often with 80180014). To allow this scenario:
    1. In the Intune admin center, go to Devices > Enroll devices > Enrollment device platform restrictions.
    2. Select Windows restrictions or create a new restriction.
    3. On Platform settings, set Personally owned devices to Allow.
    4. Assign this restriction to the user/group that should be allowed to enroll personal Windows devices.
    After these changes, retry setting up the Surface Pro with the business account.
